blower motor issues
Old Oct 9, 2017 | 01:02 PM
freds 95's Avatar
freds 95
Default blower motor issues
Hey everyone, I have a 95 ram 3500, problem is I can turn the blower motor on without the key even being in ignition, have come out to dead batteries because it didn't get completely shut off. Any ideas? thanks
Old Oct 9, 2017 | 07:41 PM
It appears the blower motor gets power directly from the ignition switch. Then thru the fuse block (fuse F2, 30 amp) then to the motor. So, you either have a short to power somewhere, or, a bad ignition switch. Does anything else still work with the ignition off?
Old Oct 10, 2017 | 10:45 AM
Mark S.'s Avatar
Mark S.
My 96 Dodge had a recall to replace some wiring in the steering column. I believe there was a problem with too much current draw from blower motor, shorting some wires in column.
