Oil leak.
Old Oct 15, 2017 | 12:43 AM
Cweldy's Avatar
Cweldy
After some searching, it looks like this is a good possibility.
Old Oct 15, 2017 | 12:44 AM
AtomicDog's Avatar
AtomicDog
Originally Posted by Cweldy
Anyone know the thread size of the pressure sensor?
I believe it's 1/8" pipe thread.
Old Oct 28, 2017 | 08:02 AM
Cweldy's Avatar
Cweldy
Yep. Got mechanical gauge hooked up and it's holding about 15psi at idle when warm. Got the plenum gasket changed along with the valve cover gaskets. Doesn't seem to be leaking anymore. I think most of the leak was from the intake gasket.
Old Oct 28, 2017 | 09:55 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
It's enough to leave a small spot overnight. Seems like more than a valve cover gasket, although I think they need changed. I have had the truck for less than 2 weeks. It's a 96 1500 with 150k on it.
Wash the engine and use a leak detector if the source hasn't been pinpointed. If the oil pan has ever been removed, a leak can form if the surface area was not cleaned and no sealant used in the corners where the rear main contacts the block.
Old Oct 28, 2017 | 03:08 PM
2bit's Avatar
2bit
This would be a really good time to replace your timing chain and water pump.
