Not sure if I'm in the right place, new here
Old Oct 24, 2017 | 09:40 AM
03DURANGOGAL's Avatar
03DURANGOGAL
Unhappy Not sure if I'm in the right place, new here
We have a 2000 Dodge Ram 1500 and it runs like a raped ape. However someone tore out the. Top of the Dash and I'm thinking it's because all the gauges lights and all are not working. And also we are getting a no bus warning. And the wipers won't work. So looking for some input if anyone can help. All I know for $1000 and runs awesome I got a deal. But a bit ill about the Dash tore up. I appreciate any and all help. Thanks
Old Oct 24, 2017 | 10:03 AM
cruzer55's Avatar
cruzer55
LMC TRUCK.COM ,FOR ALL MOST TRUCK PARTS YOU NEED FOR FIXIN THE LITTLE THINGS.Give them a look for things you need& want.Welcome to the forum.................
Old Oct 24, 2017 | 10:32 AM
You want to be in the 2nd gen ram section. (I'll move the thread)
You can download a service manual for your truck from here.
Old Oct 24, 2017 | 11:45 AM
03DURANGOGAL
Thanks y'all. I was hoping some had the same problem and could enlighten me a bit more. I watched a few videos on the no bus problem gonna try those or just get a pull a part computer and see if that helps that problem. As far as the Dash I guess we may have to install our own odometers. Idk just lost. It's a great truck besides these issues.
Old Oct 25, 2017 | 06:37 AM
Moparite's Avatar
Moparite
Check the connectors that go on the pcm, There have been other with no bus issue that it was a bad connection at pcm. You can search for other posts that relate to the no bus. Just use the "search this forum" at the top.
Old Oct 25, 2017 | 07:46 AM
ramsportrocks's Avatar
ramsportrocks
the reason the top of the dash is gone is because they are KNOWN for cracking and falling apart
as moparite states " check the pcm connection " I have seen where a couple of the pins had rust on them
causing an issue.. some careful cleaning and dielectric grease can hopefully fix it if this is your issue
Old Oct 25, 2017 | 12:33 PM
03DURANGOGAL
Yeah we did that and I will look it up under no bus. Thank you.
