Engine identification/build
Old Oct 27, 2017 | 11:51 AM
BigRedRam95's Avatar
BigRedRam95
Default Engine identification/build
Hey everyone it's been a while since I have been on. Today I was given a magnum engine that I'm told has 5000 miles on it. They guy just needed out of his shop so he can move in a paint booth. I'm needing to know what year it is and if it's a 5.2 or 5.9. If it will bolt into my 95 with the 5.2 I was going to build it on the stand and swap them over. I'm just not sure how to tell.
Old Oct 27, 2017 | 11:53 AM
Look on the drivers side of the block, engine size and other info is cast right into it.
Old Oct 27, 2017 | 12:09 PM
BigRedRam95
Block says 53020006-360 so I'm assuming it's a 360 then
Old Oct 27, 2017 | 12:13 PM
Yep. Unfortunately, it doesn't give any year information there. Same number from 92-02.....
Old Oct 27, 2017 | 12:32 PM
BigRedRam95
So is there anyway to tell what year the engine is? The intake does not have a devider plate in it like my 95 has. It also does not look to have egr on the intake. My main concern is would it be worth building this engine in the shop and swapping it over into my 95. I was going to build the 5.2 but if I could build this one it would be even easier to have the truck running until I'm done building this one. I have rt heads for it which should work on the 318 or 360. The only problem is I have a mopar performance 318 computer to put in which won't work with the 360 correct?
Old Oct 27, 2017 | 12:36 PM
Plastic or metal fuel rail? Male or female fuel line connection? No EGR indicates 96 or newer, no center divider makes it even newer. You could use the long block, but, in order to keep your computer happy, you would have to use the exhaust, and intake manifold (and all the sensors) from your original engine.
Old Oct 27, 2017 | 12:45 PM
BigRedRam95
So is crank and everything internal the same on the 5.2 vs the 5.9 other then the camshaft?
Old Oct 27, 2017 | 12:51 PM
Lots of differences between the 5.2, and 5.9, bore, stroke, cam, etc. they are externally dimensionally identical though, so, a 5.9 will bolt right in to where a 5.2 sits. 5.9 is also externally balanced, so, you MUST use the correct dampner/flexplate on the 5.9. Given yours is OBDI, you will need to find a new computer for the combo.
Old Oct 27, 2017 | 01:12 PM
BigRedRam95
That's what sucks for me need to find another computer because I bought the mopar performance computer not too long ago
Old Oct 27, 2017 | 01:49 PM
BigRedRam95
I have a good bit of parts for the build already. I have the rt heads, hs 1.6 rockers, new set of lifters, long tube headers An intake off another 95 that is already modified. Just need decide if I want to epoxy fill it or leave it alone. I have the new aluminum plenum plate and gaskets. So I have a start just need help figuring out how to start
