Rear diff pics
Old Nov 10, 2017 | 09:20 AM
  #21
Originally Posted by 2bit
Use a 90 degree die grinder with 3M roloc scotch brite pads https://www.fisheriessupply.com/3m-r...bly-with-shank https://www.3m.com/3M/en_US/company-...3241340&rt=rud
You can get scotch brite pads, sanding discs, bristle discs. They are awesome. You can use an electric drill if you don't have a die grinder.
I LOVE those things. Makes cleaning gasket surfaces almost pleasurable. Almost.
Old Nov 11, 2017 | 06:36 AM
  #22
Sheriff420's Avatar
Sheriff420
I use a brass wire brush for a drill (for the low speed vs a grinder) with the differential wrapped up in tin foil to get the RTV off. I went from 10 minutes of scraping to 30 seconds of wire brushing with the drill when I take my covers off.
After changing mine a few times I got lazy and picked up a $7 drill pump along with some clear tubing and now I drain mine without taking the covers off.
