frontend clicking
Old Nov 5, 2006 | 08:22 PM
Darren's Avatar
Darren
Default RE: frontend clicking
I was thinking of changing the hub assembly but it is removed now and it seems pretty smooth, but maybe it is a different story when the wheel is under torque. the axes are out now also and the u joints are fine no play at all. thanks Also I removed my suspension arms on the left side to insect them, and when trying to loosen the lower arm front bolt I snapped the head rate off. ( the bolt with the cam adjuster) Are you supposed to have the left and right cams at the same notch? thanks
Old Nov 5, 2006 | 08:24 PM
Darren's Avatar
Darren
I was thinking of changing the hub assembly but it is removed now and it seems pretty smooth, but maybe it is a different story when the wheel is under torque. the axes are out now also and the u joints are fine no play at all. thanks Also I removed my suspension arms on the left side to inspect them, and when trying to loosen the lower arm front bolt I snapped the head rate off. ( the bolt with the cam adjuster) Are you supposed to have the left and right cams at the same notch? thanks
