3" suspension lift
Old Nov 14, 2017 | 02:34 PM
Rammit82's Avatar
Rammit82
Default 3" suspension lift
I have a 4wd truck. I have the 3" coil spring. Has a pretty stiff ride so I bought the new 3" control arms, Pittman arm and the sway bar drop down bracket. Will I need the track bar drop down bracket as well? I've looked up suspension lift kits online and I see all the parts except the track bar bracket. What do y'all say? If I don't need it I'm sending it back.
Old Nov 14, 2017 | 03:03 PM
install everything else, and see where your axle sits under the truck. If it is centered enough for you, don't worry about it, if it ain't, install the bracket.
Old Nov 15, 2017 | 01:19 AM
Ramman18's Avatar
Ramman18
What causes stiff ride is not the lift, but the hydro shocks and LT tires. Once I upgraded to gas shocks and kept psi under 45, the ride got a ton softer.
And for my lift, all I added was the lower control arms (which I got for the quality since they aren't any longer) and the adjustable track bar. Nothing else is needed. A 3" lift on a half ton is about what a 2500 looks like and they used the same parts so there's room to grow a 1500.
