2000 dodge ram 1500 5.2 Climate control problems
When I want to turn air to low heat it go's right to hot I can not get it to blend the air right I know the blend door is working I replaced the moter that moves it I don't know what to do please help!
If you removed the motor, then the interposer is most likely cracked.
You'll need this now:
http://heatertreater.net/dodge-ram-95-02
