Engine interchange
Old Nov 20, 2017 | 12:21 AM
Cweldy's Avatar
Cweldy
Default Engine interchange
What year engines will be a fairly easy swap into my 96 1500 with 318? And will a 318 from a van work?
Old Nov 20, 2017 | 08:09 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Depends, what year is the van? The intake made some changes over the years...
Old Nov 20, 2017 | 12:05 PM
Cweldy's Avatar
Cweldy
Its a 92. I plan on using my intake and accessories.
Old Nov 20, 2017 | 12:23 PM
Was 92 still the old LA block? If so, it won't work. Too much is different.
Old Nov 20, 2017 | 01:07 PM
Cweldy's Avatar
Cweldy
I can't find a solid answer on when the switch was made. According to Wikipedia it ended in 91. Some forums say 92.
Old Nov 20, 2017 | 01:24 PM
318 went to the magnum version in 92, 360 in 93. So, technically, the 92 318 block should work. (check the angle of the intake manifold bolts. Should go straight down into the heads.)
