obd1 code reader
Old Nov 24, 2017 | 06:24 PM
hestersty@gmail.com's Avatar
hestersty@gmail.com
Default obd1 code reader
Where can you buy an obd1 code reader for a 1984 dodge pickup?
Old Nov 24, 2017 | 06:28 PM
hestersty@gmail.com
Default obd1
Where can you buy an OBD1 code reader for a 1984 dodge pickup
Old Nov 24, 2017 | 07:40 PM
Torxhead's Avatar
Torxhead
I have obd1 fuel injection in my '86 Jeep CJ and use an Actron reader that I bought from Actron years ago. Otherwise, I can use a paper clip to connect two of the terminals in the plug that is used for the emissions inspection. With the key in the on position, I can determine if there are any codes being sent by reading blinking check engine light flashes. You should be able to find out how to read codes from a repair manual for your truck.
Old Nov 24, 2017 | 08:07 PM
AtomicDog's Avatar
AtomicDog
I use an older Snap On MT2500 scanner with the appropriate cartridge and connector. You can usually find good used units on craigslist or eBay.
Old Nov 25, 2017 | 08:54 AM
Obd 1 you can use a paper clip to read the codes.
Old Nov 25, 2017 | 10:32 AM
Moparite's Avatar
Moparite
http://www.allpar.com/fix/80s-codes.html
Old Nov 25, 2017 | 02:26 PM
moparracing's Avatar
moparracing
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
