Hella 500 Fog Lights
Old Nov 27, 2005 | 03:12 PM
raiders fan's Avatar
raiders fan
Default Hella 500 Fog Lights
Need some help folks. Trying to wire these fog lights up. Using a relay with a on/off toggle switch. The directions say to wire the toggle from the relay and also from the High Beams. I cant locate the high beam fuse. Anyone know where to locate or where to wire this toggle? I have the 2004 Dodge Ram 1500 4.7 ltr. Thanks.
Old Nov 28, 2005 | 01:52 AM
2kramquad's Avatar
2kramquad
Default RE: Hella 500 Fog Lights
Are they fog lights or driving lights? All fog lights I've ever had tell you to wire them into the low beams. I always found it easiest to go back to where the plug is at the headlight itself and tap into the correct wire there.
Old Nov 28, 2005 | 01:45 PM
ljpierce_ely's Avatar
ljpierce_ely
Most Fog and Driving lights are illuminated only when the Low Beams are on. The easiest way I have found to find that wire is to look at the connector on the headlamp. If you have an electrical tester, so much the better. Due to space constraints, and the fact I'm not into Yoga, getting under the dash and looking for wires tends to be more frustrating and painful than just looking under the hood!!
