Heater core?
Old Nov 30, 2017 | 06:49 PM
If it was an aftermarket sensor, (not Mopar....) then it may still be the problem. Our trucks REALLY don't like aftermarket sensors in critical locations.
Old Nov 30, 2017 | 07:25 PM
Scottmed1's Avatar
Scottmed1
It runs like **** too, I gotta warm it up for 15 min or it won't even climb the hill outta my driveway
Old Nov 30, 2017 | 07:29 PM
Get a real mopar sensor...... Its also possible you have other problems going on as well.....
Old Dec 1, 2017 | 07:43 AM
Scottmed1's Avatar
Scottmed1
I know, a local mechanic put it on the computer and said that when the truck looses power and won't climb hills the pcm is loosing communication but once the vehicle warms up it runs fine
Old Dec 1, 2017 | 08:51 AM
Ugh. Something is failing when cold...... Could try hitting the PCM with a blow dryer, warming it up good before trying to drive it. If that works, replace the PCM.
Old Dec 3, 2017 | 08:52 AM
madmikesmech's Avatar
madmikesmech
That's a great idea HeyYou! Way to think outside of the box!!
In colder climates (like western N.Y. state, where I reside) having warm defrost is more than a " creature comfort"! As I WELL KNOW! Freezing rain, and no WARM defrost becomes a safety issue!
Changing the heater core, I understand is a real pain in the ***, but if the truck is decent shape, probably well worth the effort
Old Dec 3, 2017 | 09:23 AM
Moparite's Avatar
Moparite
They make two different styles of heater cores. The oem style and one with swivels on the lines. The one with the swivels are made so you don't have to completely remove the hvac box(and disconnect the ac lines). The down side is they tend to leak at the swivels. You can also cut most of the oem style lines down and just run the hoses in through the fire wall or use a piece of hose to go through it.
Old Dec 3, 2017 | 12:14 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Everyone says this, but when I replaced the heater core in my '97 with the OE style, I was able to wriggle and jiggle it into place without having to remove the HVAC box. Maybe I got lucky, or maybe I have dumb luck? I did buy one with the swivel tubes, and after one look I returned it as I could see it becoming a problem.
Old Dec 3, 2017 | 04:55 PM
Ramman18's Avatar
Ramman18
Good to know, Gary. When I get around to mine, I'm putting in the OEM again but I'll do it with the box still in. I've read too many bad stories about the swivel cores too.
Old Dec 5, 2017 | 01:40 AM
Ramman18's Avatar
Ramman18
Found some writeups where they just use hoses and clamps to attach the new core. That seems like a better place to leak than the swivels.
What brand core is best? Rockauto has only a few no-names and they don't mention swivel tubes. This will have to be a quick job for me so I'm not doing the AC lines. Either hoses attached inside or outside for me. Hmm. Napa sells the swivel but I haven't found any copper cores anywhere like OEM.
