Crush sleeves
Old Dec 5, 2017 | 02:28 AM
Rammit82's Avatar
Rammit82
Default Crush sleeves
Anybody know of a video that explains how to install a crush sleeve on a rear pinion and the torque specs. I'm hoping I can put this in to eliminate the whining and looseness of my bearing. Thanks
Old Dec 5, 2017 | 12:46 PM
Procedure is in the service manual..... You can get one here.
Old Dec 5, 2017 | 07:41 PM
brian102's Avatar
brian102
ton's of videos on youtube. there's also a crush sleeve eliminator for the 9.25. a bit more hassle to get it set up right, but eliminates the possibility of your pinion loosing preload. crush sleeve's crush, solid spacers don't.
Old Dec 5, 2017 | 10:42 PM
AtomicDog's Avatar
AtomicDog
+1 on the solid spacer. It works great and uses shims along with the spacer to get the bearing preload set right.
Old Dec 11, 2017 | 11:47 PM
Rammit82's Avatar
Rammit82
Not sure what u mean atomic dog. This is the first time doing this. I m not even sure where to put the sleeve in the first place. I'd like to try to get it done myself without taking it to a shop. Any helpnis appreciated . Thanks
Old Dec 12, 2017 | 09:14 AM
AtomicDog's Avatar
AtomicDog
Here is a video explanation of the difference between using a crush sleeve vs. a solid spacer.
If I were you, I'd take your differential work to someone experienced in doing that type of work. In my humble opinion, the parts involved are just too expensive for trial and error.
