No starter or blower working
Old Dec 7, 2017 | 01:51 PM
u-shoot-irak's Avatar
u-shoot-irak
Default No starter or blower working
Starter and blower was working fine. Now nothing. I replaced both relays. Any ideas. I'm stumped. I accidentally posted same in Durango section I have 98 ram with 02 318
Old Dec 7, 2017 | 02:39 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Did you check fuses and grounds?
Old Dec 7, 2017 | 10:56 PM
CJSuhr's Avatar
CJSuhr
http://dodgeram.info/tsb/1996/08-32-96.htm
i know your truck is a 98, but read through this and it might help.
Old Dec 9, 2017 | 12:10 PM
u-shoot-irak
Thanks for your reply fuses are good I will redo all the grounds. I'm getting lights and everything else and replaced relays for starter and blower. Old ones are probably still good because I have the same results. No click or anything to the starter. I did replace the starter with a junk yard starter. Maybe another bad one or a bad ground somewhere
Old Dec 9, 2017 | 12:15 PM
u-shoot-irak
Thank you for the link. Truck was running fine. Then both just quit at the same time. I will get a voyage meter to the fuse box if it's not just a bad ground somewhere. Thanx for the research
