lifting my 2wd
Old Oct 29, 2011 | 07:41 PM
97_ram1500's Avatar
97_ram1500
Default lifting my 2wd
ive got a 97 ram 1500 ext cab. looking to fit 35s, already planning to do lift spindles, blocks, and 2 inch body lift but i know i'll need more. any advice is more than welcome and links are highly appreciated.
Old Oct 29, 2011 | 08:31 PM
stewie01's Avatar
stewie01
How much are you planning to lift the suspension? I'm thinkin that 3" is the most you can get before you have to start replacing front suspension parts, unless of course you've already accounted for that.
And I've looked myself at body lifts and seem to have a hard time finding ones that aren't only for the "Sport" model.
Old Oct 29, 2011 | 09:50 PM
aim4squirrels's Avatar
aim4squirrels
Personally, I think you're going in the wrong direction for a 2wd.
Old Oct 29, 2011 | 10:11 PM
gdstock's Avatar
gdstock
I was thinking the same thing. I do not see any benefit to lifting this truck. My 4x4 Toyota has 35's but do not see any benefit to lifting 2wd Ram.
Old Oct 29, 2011 | 10:40 PM
EndIsNear's Avatar
EndIsNear
Lifting a 2WD is just as practical as lifting a 4X4. You don't have to have a front differential to need clearance. I see it just as useful to avoid my crossmember dragging the ground.
As for the lift, 2.5" is the highest you can go without new upper control arms. Your going the right direction though with the spindles. Keep in mind that they do widen your front stance a few inches. As for the body lift, im not a fan of them, and I don't know if your an auto, but 2" body lifts are only for manual transmissions if I remember correctly. 3" is the lowest for autos. If it were me, I would go with the spindles, then add a 2" spacer and you wouldn't have to worry about the body lift, and gain the added 2" in clearance...
Old Oct 29, 2011 | 10:45 PM
DodgeItRamIt97's Avatar
DodgeItRamIt97
I have a 97 1500 2wd and it has a 2 inch level with a 3 inch body lift, and I would probably be able to squeeze some 35s on it but i would probably have to have some minor trimming of the wheel wells, but you cant know for sure unless you mount the tires and see. But I am putting 33s on it and that seems like it would be just right for my 5 inch lift.
Old Oct 29, 2011 | 10:48 PM
EndIsNear's Avatar
EndIsNear
Im running 33s on 2.5"-3" lift no rubbing, no trimming
Old Oct 29, 2011 | 10:57 PM
DodgeItRamIt97
Hmm I was wondering if a 3 inch would fit 33's, is it a pretty tight fit?
Old Oct 29, 2011 | 11:01 PM
EndIsNear's Avatar
EndIsNear
Nah. Not bad at all. But I have BFG ATs so some tires might be different. But I never had any rubbing issues, and they fill the fender wells nicely. Not to much, but don't look too small
Old Oct 30, 2011 | 08:05 AM
joekool4's Avatar
joekool4
I'm running WIDE 32's and theres plenty of room. My tire guy wanted to go with thinner 35s but I want to get gears before I go any taller.
