Torque
Old Nov 27, 2005 | 09:22 PM
Sebesta89's Avatar
Sebesta89
Default Torque
Does anyone know the TQ specs for a 5.2 and a 5.9?
Old Nov 27, 2005 | 09:39 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Torque
3.9
175hp
230ft-lb
5.2
230hp
300ft-lb
5.9
245hp
330ft-lb
8.0
310hp
450ft-lb
It can vary by 5-10 depending on what year truck you have.
This question sure gets asked a lot. Someone should really pin a thread with this info in it. [>:]
Old Nov 27, 2005 | 11:33 PM
steve05ram360's Avatar
steve05ram360
Default RE: Torque
yup, I have started a FAQ that I can add this to it... I can also pin it to the top since i'm a mod now.
Old Nov 28, 2005 | 01:37 AM
HemiMan4451's Avatar
HemiMan4451
Default RE: Torque
What about the 2nd gen cummins diesels, hp and torque output on those?
Old Nov 28, 2005 | 01:51 AM
1500sport's Avatar
1500sport
Default RE: Torque
ORIGINAL: HemiMan4451
I don't have the numbers off hand but it depends on the year and if it is an auto or stick and if a stick, 5 or 6 speed.
Old Nov 28, 2005 | 12:36 PM
The Burning Rom
Default RE: Torque
As was mentioned, it varies quite a bit depending on what you have. Almost every year they'd crank the power up a little more. Finally, with the 3rd gens, they designed a transmission that could handle the motor. [8D]
1994
12 Valve CTD
Manual
175 hp
420 ft-lbs
Auto
160 hp
400 ft-lbs
1995
12 Valve CTD
Manual
175 hp
430 ft-lbs
Auto
160 hp
400 ft-lbs
1996, 1997, 1998.5
12 Valve CTD
49 State Manual
215 hp
440 ft-lbs
CA Manual
180 hp
420 ft-lbs
Auto
180 hp
420 ft-lbs
1998.5+, 1999, 2000
24 Valve CTD
Manual
235 hp
460 ft-lbs
Auto
215 hp
420 ft-lbs
2001, 2002
24 Valve CTD
6pd Manual
245 hp
505 ft-lbs
5spd Manual & Auto
235 hp
460 ft-lbs
