A new distributor?
Old Dec 13, 2017 | 10:09 PM
Dodge dude426's Avatar
Dodge dude426
Default A new distributor?
Are there really no distributor options available for our trucks? Ok let me back up, I have an '01 ram with the 5.2L 2WD and 142K miles. I went to do an ignition upgrade on my truck so I got some Taylor 9mm wires and some E3 plugs and wile I was at it I got 2 new O2 sensors. The only distributor I found is a full on race version from Jegs (part# 310-77901) and this thing is 360 degrees of awesomeness tons of pickups, programmable and supports any power adder turbos, blowers, No2 or what have you but with that said it's also $461. Now don't get me wrong there's really nothing wrong with the distributor that's in my truck now so I don't need to replace but I guess I just want to. My truck runs like its new but i can't help to think the engine would run at least a little better with a new one. I've called MSDs hotline and the guy I talked to said they don't make a distributor for my application, Mallarey said the same thing. Nobody seems to have a pro bullit distributor for a 2nd gen ram. (dam it)
​​ I can plug my scan tool in and watch the timing curve and it swings all the way from 8 degrees adv to 21 degrees adv witch tells me that the brass barings are worn out so I think thats what is throwing my timing off but you would never know this by watching the tack. The only other option that I can find is an OE replacement that all the big corporate part store have O'rielly, pep boys, napa or whoever rockauto, parts geek and autoanything.com are samething. Am I over looking somthing or are thoes our only options?
Old Dec 14, 2017 | 09:33 AM
AtomicDog's Avatar
AtomicDog
When I swapped motors in my truck a while back, I replaced the distributor in my truck with a reman'd unit, as I noticed the kind of wear in the distributor that you described. Also made sure I had a distributor cap with brass contacts along with a good set of 8MM spark plug wires and that was good enough for me. I also changed out the timing chain to a double roller timing set and installed a timing chain tensioner. My timing has been rock solid ever since.
Old Dec 14, 2017 | 08:07 PM
Moparite's Avatar
Moparite
The pcm adjust timing not the distributor so it will change. I think you are confusing timing and fuel sync.
I suppose you could mod one(aftermarket) from a LA motor to work. Don't need vac or centrifugal advance just something that tells the pcm what the cam sensor is doing and give spark the the plugs.
Old Dec 14, 2017 | 09:59 PM
chevelle68's Avatar
chevelle68
I don't think you are overlooking anything. However, if it aint broke don't fix it. I also have an '01 with 165K with pretty much original everything (starter, alternator, distributor, O2 sensors, even the brake fluid never been flushed). I just do cap, rotor, and wires. I have also done the timing chain and hughes plenum kit. Only do like 3-4K miles a year now but it runs great. If something were wrong, to a certain extent you would notice it in the RPMs.
Old Dec 14, 2017 | 10:00 PM
Dodge dude426
Thanks moparite, I forgot about the pcm adjusting timing I just assumed the shaft was wobbling inside the body of my distributor throwing the off the timmig. But I suppose it could be a little of both. Are you saying I can get any distributor with the right plug would work? If so thats really kinda my dilemma here because like I said the only two distributors i found that would work in our trucks or that have the plug anyway are the two I mentioned. Do u know of another?
Old Dec 15, 2017 | 11:02 AM
Summit sells two different replacement distributors, for under 100 bucks...... One of 'em is a cardone remanufactured unit, so, should be available at your local parts store as well. (and it's like 55 bucks.....)
