Ping under WOT/Load
Old Dec 15, 2017 | 06:57 PM
Maximillio's Avatar
Maximillio
Default Ping under WOT/Load
Title says it, didn't used to happen but now when you romp it, it sounds like a can of marbles until you let off :P
I know this is an issue that shows up over age/maintenance periods, what is usually the cause(s) of it?
Old Dec 15, 2017 | 07:09 PM
Moparite's Avatar
Moparite
Low octane fuel or too hot of a plug. Try a higher octane fuel.
Old Dec 15, 2017 | 08:16 PM
Or blown plenum......
Old Dec 15, 2017 | 08:17 PM
Cweldy's Avatar
Cweldy
Look up plenum gasket issues. See if you have more symptoms.
Old Dec 15, 2017 | 08:24 PM
Torxhead's Avatar
Torxhead
I get engine ping when I don't travel at highway speeds for a while due to carbon buildup in the combustion chambers. Sometimes it helps to use a gasoline additive to prevent that. Going to a less restrictive exhaust helps also.
