Help
Old Dec 16, 2017 | 05:29 PM
grassman50's Avatar
grassman50
Default Help
Hello new to the site, I have a 2001 dodge ram 2500 4x4 5.9 gas. I had to remove fuel tank to put on new brake lines. I put this fuel tank back in several times and I'm at a loss. I am leaking fuel at the quick connect where the line plugs in to fuel pressure regulator on the tank. any ideas or suggestions ????? Thank you in advance
Old Dec 16, 2017 | 09:25 PM
You are in the wrong section. Moving this to the second gen ram section.
Probably need to replace the o-rings in the quick connect.
