Curious for what rear ends are compatible
Old Dec 21, 2017 | 10:47 PM
Lmorris81's Avatar
Lmorris81
Default Curious for what rear ends are compatible
Hey guys I’m new to the forum and the other night my pinion nut backed out of my 2002 Dodge Ram 1500 quad cab 4x4 with the 5.9L magnum I was hoping it would be a simple fix but I took the cover plate off and saw my inner bearing all over the place and it destroyed my gears I’ve got the 9.25” ring gears with the 3.92 LSD and I’m wondering what other rear ends would fit in there without to much modifying I’d much rather get a better one that will hopefully last longer since I only have 124,000 miles on the truck and I had a diff fluid change at 100k thanks for the help in advanced I’ve gotta get it back on the road by Tuesday
Old Dec 22, 2017 | 10:15 AM
The corporate 9.25 IS a good rear diff..... Why the pinion nut failed becomes the question. Of course, now that it already has failed...... all that's left is to clean up the mess. Given your truck is a third gen, I don't know if any of the second gen rears (which also used the 9.25 in the half ton trucks....) will swap in there..... A similar diff out of a third gen should be a direct swap though.
Old Dec 23, 2017 | 11:46 AM
fj5gtx's Avatar
fj5gtx
I had a 2004 3rd gen since new, until 2015 - about 150k miles. The 9.25 is a fine rear end, however the big problem is the way the LSD diff sits in the housing. There are .... bushings? ... that crack and come apart, grind the hell out of the housing, then if the metal shavings from the grinding doesn't take out your bearings, the bushing pieces will finally get loose in the housing, and make a real mess of gear teeth. Mine took out the tone ring. Dodge came up with the strategy to make the owners pay for excessively frequent rear lube changes, so they could put new bushings in when they broke. I tested my LSD a couple times on ice to see how it locked up, I wasn't real impressed. However in 4x4, you couldn't stop that truck.
I recommend finding a non LSD unit to make sure you don't have housing issues, then put an aftermarket diff in there along with the gears you want. Then you have a permanent solution.
This thread should be in the 3rd gen section...
Old Dec 23, 2017 | 12:12 PM
Moparite's Avatar
Moparite
If the stock limited slip unit doesn't grenade it will wear out(friction plates). Get a trutrac...
http://www.eaton.com/Eaton/ProductsS...trac/index.htm
Old Dec 23, 2017 | 12:18 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
2nd gen 9.25 will fit just have to change the combination valve to your 02 valve so keep it
Old Dec 23, 2017 | 02:13 PM
Lmorris81's Avatar
Lmorris81
Well my initial problem was the pinion nut fell out while going down the road and dropped my driveshaft and when that happened the inner bearing for the pinion shaft got knocked out of place and destroyed all the teeth on my ring gears and carrier I’m just trying to find something to keep it going until I get the parts in to rebuild mine but I only have 124,000 and had a diff fluid change at 100k but dodge won’t do nothing seeming how the same rear end for the next year or so had a recall for faulty pinion nut and also sorry I don’t know how to put stuff in the 3rd gen section yet I thought it was there to be honest
Old Dec 23, 2017 | 09:27 PM
AtomicDog's Avatar
AtomicDog
To get you going quickly, can you possibly find another complete working 9.25 3rd gen rear from a salvage yard, craigslist or wrecked 3rd gen truck?
Old Dec 23, 2017 | 09:37 PM
Lmorris81's Avatar
Lmorris81
Yea that’s what I’m gonna try to do after Christmas hopefully I can find one with the same ratio as mine if I had the money I would just swap the front and rear with 4:10 and be a lot happier I’ve been on the phone with Dodge a couple of times about the matter but they won’t admit to the problem so I’m just gonna swap it with a used one until I can get the parts for a rebuild if imagine it’s not that hard to straight swap them I was planning on replacing pinion seal and cover gasket and changing fluid once I get the used one to hopefully make it last for a little bit
Old Dec 23, 2017 | 09:45 PM
Hardest part is moving them around. Them fellers are HEAVY!
Old Dec 23, 2017 | 09:47 PM
Lmorris81's Avatar
Lmorris81
Yea I bet 😂😂😂 I was planning on supporting new one on jack stands and just leaving wheels on and just unbolting it and rolling it out then vice Vera’s for new 😂😂
