sport headlight conversion
Old Dec 28, 2017 | 04:15 PM
byteme's Avatar
byteme
Default sport headlight conversion
I have a base 01 1500 and picked up new sport head light assemblies cheap , can I swap out the base headlight harness for a sport harness or will i have to change something else for all 4 lamps to work and not burn down thanks
Old Dec 28, 2017 | 06:33 PM
I think the harness would also have to include the PDC.... as I think the highbeams are controlled via relay on the "real" sport trucks.
Old Dec 29, 2017 | 08:31 PM
Ramman18's Avatar
Ramman18
There's a relay kit sold on LMC just for this purpose. I've thought about doing this but my headlights are fine and that's one area I won't mess with (for safety).
Old Jan 2, 2018 | 01:43 PM
byteme's Avatar
byteme
Thanks but what is PDC ?
Old Jan 2, 2018 | 02:17 PM
Power distribution center. Black box under the hood behind the battery. You can check and see if the headlight relay spots already have wires in 'em.... I am pretty sure the harnesses are different though.... I *think* LMC Truck, or someone... makes a conversion relay harness? But, not 100% on that.
Old Jan 2, 2018 | 09:48 PM
2bit's Avatar
2bit
Daniel Stern Lighting has a conversion kit. The RIKRAM I think.
Old Jan 3, 2018 | 09:23 AM
AtomicDog's Avatar
AtomicDog
LMC does make harnesses for changing the headlights over to using relays, however, I believe their setups are for either non-sport or sport style headlights (two different harnesses). Since my truck has the non-sport headlight harness, I ordered that LMC harness some time ago, but have not had time to install it. In the meantime, I decided to convert over to sport headlights and I've already picked up the sport headlight assemblies.
Old Jan 3, 2018 | 09:29 AM
AtomicDog's Avatar
AtomicDog
Thanks for the info. I just took a look at his web site (https://www.danielsternlighting.com/.../products.html) and noticed that the RIKRAM kit likely has components to make up your own relay harness without the wiring and the HARN-RIKRAM is the actual complete harness. Do you (or anyone else) know of anyone using this Daniel Stern harness?
Old Jan 3, 2018 | 09:27 PM
2bit's Avatar
2bit
I got the kit to use relays for the stock headlights. I haven't had time to install it yet. Nice quality components though. If I had read his site I would have bought sport headlights instead of new stock ones.
