Hot Start Problem
Old Nov 28, 2005 | 11:49 AM
Ramboy08's Avatar
Ramboy08
Default Hot Start Problem
I have a 99 Dodge 1500 4x4 with a 5.9L and i cant get it to start when the engine is hot it starts fine when the engine is cold but after you drive it for 30 mins. or so it wont start back up. Any suggestions will help thankyou
Old Nov 28, 2005 | 12:23 PM
bamory's Avatar
bamory
Default RE: Hot Start Problem
Is it dragging or just not turning over, typically the first thing I would check is the starter, to much heat can kill the solenoid on your starter. I had that problem with Ford starters...I think if you explain what its doing better someone will be able to help ya
