need help on 99 1500
Old Jan 14, 2018 | 11:32 AM
Casey Meadows's Avatar
Casey Meadows
the #3 wire yellow on my truck
Old Jan 14, 2018 | 11:45 AM
That Might be the signal wire (constant five volts) or, it might be the return wire. (should be varying voltage.... 0-5) If you are using a digital meter, it simply isn't going to react fast enough to show you what's really going on....... Wiring diagram I have is for an 01, so, wire colors don't match.
Old Jan 14, 2018 | 12:29 PM
Casey Meadows
thanks i was
Old Jan 14, 2018 | 01:17 PM
A test light *might* work....... you should see it blinking......
