Axle nut
Old Jan 7, 2018 | 05:57 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Axle nut
2001 Dodge Ram 2500 with 1500 access was reading here (and yes I have all the FSMs) and people were saying the axle nuts can't be reused and are left hand threads. I reused mine and they were right handed threads... Did I f*ck something up?
Old Jan 7, 2018 | 06:16 PM
AtomicDog's Avatar
AtomicDog
2WD or 4WD? Can you please post a photo of the front axle nut setup in question to help cut down on confusion?
Old Jan 7, 2018 | 08:45 PM
MoparFanatic21
Sorry I usually am more specific yes 4wd and it's already together the 1 11/16 nut that goes on the one able shaft inside the wheel bearing
Old Jan 7, 2018 | 09:38 PM
AtomicDog's Avatar
AtomicDog
To my knowledge, that nut can be re-used (if its in good shape) on a 4WD 2nd gen truck, as it is torqued in-place and uses a cotter pin to keep it from backing off. My original nut was pretty rusty and beat-up, so I did purchase a new one when I rebuilt the front end. It is standard right hand thread.
Old Jan 8, 2018 | 03:17 AM
MoparFanatic21
Ok thanks as that is what I thought (it's like that on my other Rams) just wanted to make sure
