99 ram van 1500 5.2 no bus.
Old Jan 10, 2018 | 07:08 PM
John Denver's Avatar
John Denver
Default 99 ram van 1500 5.2 no bus.
No bus no starting and by a technician advice I have the 4th pcm the fuel pump all sensors cam crank ...etc.spark plugs all new and still the problem is there technician still says its the pcm that I don't think so... I fired him the problem starts intermittently on and off leaving me on the middle of the street but now it won't start at all no power to the fuel pump and the gauge show empty but I have fuel more than 1/2 tank the 5 volt wire is 2.7 in the beginning I wiggle the 3rd plug on the pcm till I heard the fuel pump run then it stars but it got worse till the point of no start at all I've read lots about this problem done lots of tests repeat it several times myself and still have no clue my van its only 65000 k miles 5.2 ram 1500. What else I need to do what Im I missing ...thanks
Old Jan 10, 2018 | 08:40 PM
Where are you getting your PCM's from?
I though you were dead? You know, plane crash, and all that?
