Engine Noise
Old Jan 14, 2018 | 03:39 PM
hometheaterman's Avatar
hometheaterman
Default Engine Noise
Does this sound like a rod knock or bearings? I finally was able to get my exhaust leaks fixed, but I still. Have this noise which sounds like it's coming from behind the oil pan. The motor still has great oil pressure and runs great otherwise.
Old Jan 14, 2018 | 04:20 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
https://youtu.be/TKFNhix6Xx4
Sounds like lifters to me. Rod knock or vesting is usually deeper.
Old Jan 14, 2018 | 11:30 PM
hometheaterman
I'm also wondering if this could be a cracked flex plate. It's coming from that area. If it was a bearing, it just seems odd to me I wouldn't see a fluctuating oil pressure or poor oil pressure.
Is there a way to check the flex plate without pulling the transmission?
Old Jan 14, 2018 | 11:56 PM
Ramman18's Avatar
Ramman18
That would sound right being flexplate. Don't autos have a window you have to remove to remove the bolts? Or take off the starter to look in the trans. You could crank it around to look for cracks. There's a dust shield on the lower half of my NV3500 but don't know if autos have that.
Old Jan 15, 2018 | 04:37 AM
MoparFanatic21
They do, true name is "inspection cover" is there for this reason
Old Jan 15, 2018 | 08:41 AM
hometheaterman
There is an inspection cover, but you can only see the teeth. You can't see where it bolts to the crank which is where they usually seem to crack. I may just hope it holds together for a few months and pull my transmission once it warms up.
Old Jan 15, 2018 | 06:49 PM
If you unbolt the torque converter, you can push it back a bit, and use a flashlight, and small mirror to inspect the flexplate....... Cumbersome, but, doable.
