PCV I知 a dummy
Old Jan 28, 2018 | 01:51 PM
Aero540t's Avatar
Aero540t
Default PCV I知 a dummy
I for some reason thought the PCV valve was on the passenger side so I ended up breaking whatever is on the valve cover and then looked on the driver side and replaced the PCV in a couple minutes. So what did I break on the passenger side valve cover? There was a hose going to the air intake off of it. It痴 a third vehicle so not critical but I壇 like to use the truck soon. 2001 5.9L gas motor
Old Jan 28, 2018 | 02:51 PM
true blue's Avatar
true blue
That would be your PCV valve. The device on the drivers side is best described as a breather cap. It's allows for air circulation from the drivers side of the engine. The breather cap can either suck OR blow gases from the crankcase, depending on the engine condition.
Old Jan 28, 2018 | 07:10 PM
AtomicDog's Avatar
AtomicDog
Originally Posted by Aero540t
I for some reason thought the PCV valve was on the passenger side so I ended up breaking whatever is on the valve cover and then looked on the driver side and replaced the PCV in a couple minutes. So what did I break on the passenger side valve cover? There was a hose going to the air intake off of it. It’s a third vehicle so not critical but I’d like to use the truck soon. 2001 5.9L gas motor
Do you have a photo that you can share here in this thread of what you broke off on the passenger side valve cover so that we can all see it and be sure of what it is?
Old Jan 28, 2018 | 08:04 PM
Probably a 90 degree elbow? Rumor has it, they have them in the help section at your local parts store.
Old Jan 29, 2018 | 09:32 AM
jlake4130's Avatar
jlake4130
Liike HEYYOu mentioned, just a PVC elbow that usually connects to the air cleaner set up.
Old Jan 29, 2018 | 07:01 PM
Aero540t's Avatar
Aero540t
Yes that sounds right. Thank you
