1999 dodge ram 1500 5.2
Old Feb 1, 2018 | 09:39 AM
Lester246's Avatar
Lester246
Angry 1999 dodge ram 1500 5.2
I have just replaced the transmission on my 1999 Dodge Ram 1500, 5.2. Part # on transmission is P52119820AA. Now I am not getting any fire on the plugs? When you turn the switch on you will get temporary fire at the coil, then will lose fire. Will the sensor at the bell housing cause it not to fire or run, if so why no fire?
Many thanks
Ron
Old Feb 1, 2018 | 09:49 AM
true blue's Avatar
true blue
You're in the right area, unless the distributor or coil is unplugged.
Old Feb 1, 2018 | 09:53 AM
true blue's Avatar
true blue
Check the connector on the sensor (the one your talking about) n see if it's on all the way. did the distributor hit the firewall when the engine sagged during the tranny replacement. There are a few sensor plugs in the general vicinity that could possibly cause this.
Old Feb 1, 2018 | 10:01 AM
Lester246's Avatar
Lester246
Default 1999 Ram 1500 5.2
Thanks true blue...I will check your info. Just wondering if that sensor ALONE would cause no fire at plugs? Replaced the coil.
Old Feb 1, 2018 | 10:05 AM
true blue's Avatar
true blue
If the crank sensor is unplugged or the sensor or wiring is faulty then the coil doesn't know the engine is turning...ergo (saw someone use that word recently/emplies intelligance) co reason to fire coil.
Old Feb 1, 2018 | 02:19 PM
2bit's Avatar
2bit
The crank sensor often gets damaged when changing transmissions. It's best to get one from Mopar. Sometimes the parts store ones don't work correctly, ergo you'll have to go buy the Mopar sensor and change it again. LOL
Old Feb 1, 2018 | 02:35 PM
true blue's Avatar
true blue
woodn't it be better to get one from Dodge?!?
