Can I swap transmissions from a dodge 1996 to a dodge 2001
Electronics are different. You will need the governor pressure sensor, solenoid, and retaining clip for whatever year your truck is.
Going from 96 to 01 will work, going the other way won't, as the newer trans won't have the mounting points for the t-case shift lever. (which mounts to the body on the 98 and up trucks.)
