Replacement Headlight Assy
Old Feb 2, 2018 | 04:10 PM
vmaxept's Avatar
vmaxept
Default Replacement Headlight Assy
OK after about 30 min looking, I want to replace the stock single bulb head light assy with a 2/4 bulb system. Aftermarket I guess. I found some on LMC Trck but do not fit the 2000 Ram 3500.
Unless I missed the link.
Does appear it might cost me big $$ Any 'stock' setup I might find used - I dont think any of the year 2000 trucks came with a 4 bulb set up
I did replace the stock 'yellow' : bulbs with a super bight set Better but would like a better system
Dont post much these days. Truck doing well.. Did replace the rear brake line.. it busted on the road.. had enough with front brakes to make it home, going SLOW and using the trans. Sure glad I did not have the horse trailer
It just went over 80K last time out ..
Tnx R
Old Feb 2, 2018 | 05:10 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Tnx R
The Sports had the 4 headlight setup (yes 2000 had them). You would need LMC or Daniel Stern lighting.
Old Feb 2, 2018 | 05:16 PM
2bit's Avatar
2bit
Yeah, they say they don't fit because you need a new 4 bulb harness from the above mentioned places.
Old Feb 2, 2018 | 05:32 PM
As the folks above me have said, the sport housing will bolt right into your truck, with a bit of bumper manipulation. (and you put it back when you are done..) Just need the add-on harness to make the system play nice with four bulbs, instead of two.
Old Feb 4, 2018 | 04:41 AM
MoparFanatic21
If you are good at electrical I can walk you through what I did to make my 1 bulb setup 2 bulbs. Also add relays for the headlight switch if you can, it'll save the headlight switch.
