code P0351 2001 dodge ram
Old Feb 3, 2018 | 11:19 AM
gpdesperado's Avatar
gpdesperado
Default code P0351 2001 dodge ram
i keep getting code P0351 then i have a no fire no start i have changed the cam sensor crank sensor ignition coil and ignition switch it runs fine when its starting i can ground the black wire going to the oil and it will start makes no sense
Old Feb 3, 2018 | 11:50 AM
Changing the cam and crank sensors with aftermarket units may be a concern.... these trucks just don't like 'em.
The code is talking about the control circuit for the coil, so, either you aren't getting power to the coil, or, there is a bad connection between the coil, and PCM, or, bad PCM......
