4x4 rear end inrerchange
Old Feb 4, 2018 | 10:15 AM
angrysmileyface's Avatar
angrysmileyface
Default 4x4 rear end inrerchange
So my friend has potentially ruined the rearend on his 01 4x4 1500. What other years/models will have a direct interchange? I'm trying to make this as painless as possible for myself as my last debacle with this particular vehicle was an engine swap to replace a locked up 5.2l. All help is very much appreciated. And I will apologize in advance for not knowing what differential is on the truck or if the 4x4 models are something specific
Thank you
Old Feb 4, 2018 | 12:10 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Thank you
You have a 9.25 Chrysler rear end. Any 9.25 from 95-current will fit, the biggest problem is gears.
Old Feb 4, 2018 | 02:13 PM
angrysmileyface
Thank you for the input. It's factory so I'm sure the gearing hasn't changed. I guess I need the Vin and perhaps can get a build sheet
Old Feb 4, 2018 | 02:51 PM
Falcben's Avatar
Falcben
Where are you located?
I have a 4.10 rearend from my 2001. Truck was stolen the other night and taken for a glory ride which ended with a tree. But the rearend is just rebuilt about 5000 miles ago.
Old Feb 4, 2018 | 08:20 PM
angrysmileyface
Unfortunately I'm located in sc. I'm not sure what gear set is in it though.
Old Feb 4, 2018 | 08:35 PM
Need to find out.
