Reverse Switch
Old Feb 8, 2018 | 06:26 PM
eli_trippet's Avatar
eli_trippet
Default Reverse Switch
I have a 1999 Dodge Cummins with the NV4500. The reverse lights don't work. I replaced the bulbs and I know the fuse isn't blown. Where is the switch located?
Old Feb 10, 2018 | 02:17 PM
frankie_b_jr's Avatar
frankie_b_jr
Towards the top of the transmission, on the drivers side. Simple 2 wire plug if you can find it in all the other wires running past it.
Old Feb 12, 2018 | 02:49 PM
V65Ozzie's Avatar
V65Ozzie
Weird question, do you have an auto dim rear view? Years ago I ran into an issue with a Ram not having reverse lights, turned out to be a problem with the rear view. Only took about 2 hours to figure that out.......
