Truck clicks as if battery is dead a couple times then strts
Old Feb 12, 2018 | 10:30 AM
Tristan McLent's Avatar
Tristan McLent
Default Truck clicks as if battery is dead a couple times then strts
Recently my 01 Dodge Ram 2500 started dhaving a problem where it will click when I try turn it over as if the battery’s were dead then after a few clicks it’ll start up. Sometimes I could drive it all day then turn it off in tims drive thru and then it won’t start til I try turn it over a couple times. It usually doesn’t do this if it’s plugged in. It was also fine for the first couple months of winter
Old Feb 12, 2018 | 10:55 AM
Is the click from the starter relay, or the solenoid on the starter itself?
Old Feb 12, 2018 | 11:24 AM
Tristan McLent
I’m not sure where is the starter relay located
Old Feb 12, 2018 | 12:30 PM
In the PDC, right behind the battery. You would likely have to be listening closely to hear it.
Old Feb 12, 2018 | 02:37 PM
V65Ozzie's Avatar
V65Ozzie
https://dodgeforum.com/forum/2nd-gen...ery-handy.html
Great resource.
