Temp sensor
Old Feb 15, 2018 | 03:14 PM
mrbubblemaker's Avatar
mrbubblemaker
Default Temp sensor
hey.. I replaced a ‘95 intake manifold with a 2000. The ‘95 had two outlets, 1for the temp sensor and one for the sending unit. How can I make both work with just one outlet?
Old Feb 15, 2018 | 03:29 PM
2bit's Avatar
2bit
Can you drill and tap another hole?
Old Feb 15, 2018 | 03:56 PM
mrbubblemaker
yes but at this point I’m hoping there is another way around it.
Old Feb 15, 2018 | 06:09 PM
Nope. No place else to put the sensor.
Also, the 2000 intake won't have provisions for the EGR valve. You can leave it off, and plug the hole in the passenger side exhaust manifold. The PCM may, or may not whine about it.
