cylinder 6 misfire
Hello, I am a newcomer. I see other threads but not sure that it fits my truck. I have a 2001 5.2 Ram 4x4 235,000 still purrs for the most part. side note solid frame but typical body rot. For a few months the truck would randomly stall when I let off the gas. Sometimes several times a day. Some days not at all. My husband and friends and our local shop couldn't figure it out. Did a tune-up and put in a used coil pack. no change. Then after a couple weeks the stalling didn't occur for about a month. Last week it gave me a hard start, I ran to deli and left running and came back. Next morning for work it gave me another hard start and the engine light came on. I got down the road to stop light and it stalled and wouldn't start. I left it sit a half hour and then it started right up, engine light still on. I drove it directly to the local auto shop. They have had it four days and it starts every time but the engine light is still. It throws a code for cyclinder 6 misfire. The shop would like to install a coil. I am wondering if a faulty coil would make it stall? If it would make it hard to start, twice? and if it would throw that code? Suggestions
Faulty coil would not give you a misfire on just one cylinder.
What brand spark plugs did you install?
Think I would also yank the throttle body, remove the IAC valve, and clean things out really well. (typical cause of stalling randomly)
True Blue, honestly Idk. not that mechanicly inclined. One mechanic said he was replacing the coil pack with one he had from a parts truck. The other mechanic yesterday said he replaced ignition coil. I think they were the same part which is an ignition coil not a pack
