97 ram transmission issue
Old Feb 27, 2018 | 08:33 PM
buickcarguy's Avatar
buickcarguy
Default 97 ram transmission issue
trany goes into reverse well but no forward gears new filter and fluid and lucas was shifting ok then all at once nothing
Old Feb 28, 2018 | 10:50 AM
Unplug the 8 pin connector on the drivers side of the trans. It goes straight down into the valve body, about halfway back. See if you get any forward gears. (you will have zero automatic function......) If you don't, it's rebuild time.
