1996 1500 v8
Truck started acting up. Acting like it didn't want to really go. Kinda like it was the transmission slipping but not really. So I just replaced spark plug and wires distributor cap and idle Conrol sensor and throttle position sensor. Now my truck won't even start. It turns over. Then just sputters and junk. Any ideas???
Is the money light on? The first thing I'd try is spraying starter fluid down the throttle body whilst cranking engine. If she sparks to life, fuel starvation. Next, pull the upstream O2 sensor n see if she starts n idles. If no bueno, then my guess would be the ignition coil, seeing as how you just changed allot of stuff in the ignition circuit. If no bueno, then make note of any other symptoms n get back to the thread.
