blocking the radiator???
Old Dec 9, 2005 | 02:01 PM
  #41
livinginh's Avatar
livinginh
Default RE: blocking the radiator???
ORIGINAL: VWandDodge
ORIGINAL: livinginh
ORIGINAL: shott8283
t-stat is a stocker
Change your t-stat. Mine was acting the same way, didnt have any problems till it got cold, so I emailed the guy I bought the truck from and he told me he never changed it(still the original from 1997). I went ahead and got everything and when I pulled the housing off the t-stat came out in 3 pieces, it had totally rotted apart. And the antifreeze was like mud. Talk about someone not servicing their car. Put a new 180 in it, and freash antifreeze(Im good to -40 degrees), now warms up just liek it should and no problems.
So if your is still the original change it.
And yes when it gets to cold out, I use card board also, helps protect the radiator from the direct cold air.
Sounds to me like you aren't so good at maintenance yourself. The fluids are the first thing that should be checked/flushed when acquiring a used vehicle.
Before you start on that one, I always do regular maintanace. I knew right off at least the antifreeze needed changed but didnt look that bad, just didnt relize it had never been changed and was still the original thermastat. First things I did after getting the truck was complete oil change and check and greased everything I could. I figure did pretty good being I have only had the truck 6months, and I didnt say when I did the T-stat change, just said I did it. So please as shott8283 said dont assume we dont maintain our trucks.
Old Dec 9, 2005 | 03:01 PM
  #42
shott8283's Avatar
shott8283
thanks for the backing living!
Old Dec 10, 2005 | 05:54 AM
  #43
shott8283's Avatar
shott8283
i think i just ahd air in the system... the coolant level was lower then where it should be.. so i toped it off and started the truck...shut it off and opend the rad. cap.. did this about for or five times... heat seams to blow nice and even now... ill keep an eye on it but it seems to be ok..either way the old t-stat will come out and a new one with go in..as soon as i get a chance to do it! thakns fellas for the help!
