2000 dodge 1500 4x4 46re ??
Old Mar 7, 2018 | 02:15 PM
hardass's Avatar
hardass
Default 2000 dodge 1500 4x4 46re ??
Ok i know its been talked to death but here goes . I have a 2000 dodge 1500 ram 4x4 after about 7/10 miles or so the od off light comes on only a few time the trans temp light will come on so i pull over sit for maybe 5 minutes start the truck no lights on start driving and od will shut off again but i never get another trans temp light again. Now i have a after market temp sensor that will climb in temp to say 150 or so this is after themp light was on but is not any more.
I have done a master solenoid kit same issue it changed nothing. Now i found out about the boost pressure plate. While i was in installing the master kit i had that plate off i noticed a small hole in that plate that was made there and im not sure if that was stock or not ill search that. im at a loss here the truck has 130000 miles on it no burnt fluid or anything and seems to drive and shift great untill that happens then i gain rpm as you would expect when shifting out of od.
now when it shifts out of overdrive if you keep driving it will shift back into od for a few miles then out again and so on. Any help would be great. Also i will say when o first start the truck there is a strange noisea spinning or almost belt slip or something it last about 30 sec then gone.
Old Mar 7, 2018 | 04:25 PM
I would suspect the wrong pressure sensor was installed, but, if it was doing this before as well, time to look at the wiring.
Old Mar 7, 2018 | 06:28 PM
hardass's Avatar
hardass
Yes it was doing the exact thing before the kit what wiring are you refering to?
Old Mar 7, 2018 | 07:02 PM
from the PCM to the trans.
Old Mar 8, 2018 | 10:06 AM
hardass's Avatar
hardass
Ok i will go over that as soon as its done snowing thanks for the guidance
Old Mar 8, 2018 | 11:40 AM
Verify you are getting the correct voltages AT the trans as well....
