No speedometer and abs lights off
Old Mar 7, 2018 | 08:15 PM
Gunnerm14's Avatar
Gunnerm14
Default No speedometer and abs lights off
I have a 99 ram 1500 with 95 ram 2500 axels under it front and rear does anyone have a clue on how to get the speedo working again I replaced the abs sensor brake lights out in a complete loss
Old Mar 7, 2018 | 10:48 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Did you replace the rear diff sensor?
Old Mar 7, 2018 | 11:21 PM
Gunnerm14's Avatar
Gunnerm14
yea still didn't solve the issue and I can't get a reading even when the scanner was on it
Old Mar 8, 2018 | 08:23 AM
Do a cluster test. Hold the trip reset button in, and turn the ignition to On. (not start) That should start the test, see if the speedo tests properly.
