Plenum bad again?
Old Mar 13, 2018 | 04:18 PM
chromed95's Avatar
chromed95
Default Plenum bad again?
Hey guys. So for the first time since I did my plenum roughly 5-6 years ago but no more than 15,000-20,000 miles ago, I checked for oil pooling in my intake to see how well my hughes kit was holding up. I opened up the butterflies and shined a light in there and to my surprise I could see oil streaking as you can see in the pictures. I also remember replacing the PCV valve after I finished the plenum. Is this normal? Or have I got an issue somewhere?
I just started driving this truck again as a daily driver and have been fixing things on it. I just changed oil so I'll monitor any oil loss, but anything before that I can't remember if I ever had to add any or not. I know if does drip some oil.
On another note, when I was changing the oil filter I did notice a pretty good wet spot of oil that looking to be coming from the bottom side of the head to the block. Wondering if maybe that gasket is going TU and losing oil there. It's also loosing coolant somewhere (maybe from that same spot?). I want to get the pressure tester tool to see if I can find that leak. I know the heads on these trucks are problematic so maybe it's a sign that they are cracking.
Attached Thumbnails Plenum bad again?-intake-1.jpg   Plenum bad again?-intake-2.jpg
Old Mar 13, 2018 | 06:52 PM
That could be just from the PCV system. Put a genuine mopar PCV valve in it, check it again in a couple months.
Old Mar 13, 2018 | 08:51 PM
2bit's Avatar
2bit
I agree, try a Mopar PCV valve.
Old Mar 13, 2018 | 10:19 PM
chromed95's Avatar
chromed95
I did put a mopar one in back then, in the parking lot of the dealer parts department....If i remember right, thy were pretty cheap. Maybe try another one?
Old Mar 13, 2018 | 11:05 PM
Ramman18's Avatar
Ramman18
Nope. Looks normal to me. Just maybe dirty oil. Mine's always been shiny like that but "cleaner" in color. And my Hughes is going on 13 years solid.
Old Mar 14, 2018 | 01:54 PM
chromed95's Avatar
chromed95
Awesome, good to know thanks!
