What size spacers and lugs for 4th gen rims?
Old Mar 27, 2018 | 08:18 PM
kingofnapier's Avatar
kingofnapier
Default What size spacers and lugs for 4th gen rims?
Trying to put these on my 1999 like this guy.
Old Mar 27, 2018 | 09:39 PM
I believe you just need to open up the hub holes in the wheels, so they fit the 2nd gen truck, and you are good to go. Bolt patterns are the same, aren't they? I am just not a fan of spacers........
Old Mar 28, 2018 | 06:38 PM
kingofnapier
You mean to bore out the hub hole in the wheel? Then how will my dust caps fit?
Old Mar 29, 2018 | 07:02 AM
Not all the way thru, just enough to clear the hubs on the truck. Other option is to alter the hubs on the truck, but, then you will have to do it again if you ever replace them. Think I would test fit everything first, and see if you even NEED to do anything....... I know there are threads around her about just such a swap.
