Wheel rotation ticking noise&clattering
Old Apr 3, 2018 | 06:28 PM
C12Creed's Avatar
C12Creed
Default Wheel rotation ticking noise&clattering
1997 dodge ram 1500 4x4 5.2L Passenger side front wheel region:
As I drive, I hear a ticking noise that is in sync with the rotation of the tire. Tire has nothing stuck on it.
Also,when going over bumps I hear a clattering noise every so often.
These noises are not too loud. They can be heard when cruising at speeds below 20mph.
Any thoughts? I was told wheel bearing and ball joints are fine. I am about to change tie rods, sway bar links and bushings, and steering dampener.
Old Apr 3, 2018 | 07:31 PM
Check the u-joint in the axle on that side.
Old Apr 3, 2018 | 07:37 PM
schmidtp's Avatar
schmidtp
Sounds like the exact symptoms and sound when my u joint on the axles were bad.
Old Apr 3, 2018 | 08:11 PM
2bit's Avatar
2bit
You need to check the u-joint and wheel bearing yourself.
Old Apr 24, 2018 | 05:12 PM
C12Creed's Avatar
C12Creed
Forgot to update: Solved by replacing wheel bearings
Old Apr 25, 2018 | 11:17 PM
2bit's Avatar
2bit
Thank you. Glad you got it fixed.
