tps / torque converter / loss of power
Old Apr 4, 2018 | 01:14 PM
jackcone9's Avatar
jackcone9
Default tps / torque converter / loss of power
okay, it's a 2000 ram 1500 , I've done the coil, plugs, distcap, rotor, plug wires .. been reading up on this, it seemed that the tps was a possible cure , but somedays it's good , somedays I disconnect the battery for the reset, at times it will not shift into 20 mph without not tach'in at 2500 , and worse, even with a easy foot to feel the shift, 35 mph - 45mph there's a lot of noise / shifting going on, 45 to 55 , bogs down like it's staving , then finally interstate speed okay, I would like to believe that I bought a crap tps online ..
UPDATE 4/ 5/18 I did a overnight battery disconnect , I've been doing this a lot, but I got good results from it,
powers up- accelerates like it did when I bought it, still can rev a 23-2500 on shifts, but it does the shift rotation
okay, with a little help feathering in the pedal, you get the shift bump at 25 mph, 35-42, then at 45mph smooth
sailing... it's just a matter of time before it craps again, so it's a series of disconnecting the battery until amazon delivers
what I hope is a working TPS , that snap connects , the current one does not snap/ and was not made to snap connect ..
Old Apr 4, 2018 | 02:34 PM
May not be the TPS at all.
Have you checked the plenum yet? Some of your symptoms match up with what you get with a blown gasket. See the stickied plenum thread at the top of this forum for more information.
Old Apr 4, 2018 | 07:50 PM
jackcone9's Avatar
jackcone9
THANKS , I did watch some youtube videos , so I know what to look for, but I'm not gonna be the guy doing
the work ../ a younger man's game, with better tools , but I did buy another tps for under $20 / see what sticks !
Old Apr 4, 2018 | 10:55 PM
2bit's Avatar
2bit
If it's the plenum, it's a good time to change the timing chain and water pump. Have them check your Cat because sometimes it plugs because of the oil ingested by the leaking plenum gasket. A new O2 sensor is a really good idea, as is a thermostat. It's expensive, but my truck ran really nice afterwards. Just make sure thats what the problem is.
