Knock on startup/5.9 magnum
Old Apr 6, 2018 | 12:55 PM
Gharve88's Avatar
Gharve88
With the engine idling, fully warmed, anything over 10 PSI is considered 'acceptable'.... Personally, I still think that's a tad low, I like to see 25-30 psi at idle, fully warmed.
oh ok, so it could possibly be rod bearings? Its done this for quite awhile now on the start up. But when im driving or when it warms up i dont hear much of anything. Idles like it should and doesnt seem to run rough
Old Apr 6, 2018 | 03:14 PM
AtomicDog's Avatar
AtomicDog
Rod knock on a higher mileage motor is pretty common, however, if you could take a video of the sound you are hearing with the hood up and share it in this thread, that might help folks to help you to narrow it down. It could also be a bad exhaust leak, too.
Old Apr 6, 2018 | 03:58 PM
Gharve88's Avatar
Gharve88
ive had this knock for the last 4 years and yet it still runs fine. I mean its sluggish on power and horrible up hills but it idles smooth. Ive drivin this truck on trips the way it is and never left me stranded. So if it is rod knock how long would this last? Ill get a video as soon as i can
Old Apr 6, 2018 | 04:30 PM
Well, 4 years at any rate. That's the trouble with those kind of noises, at this point, we are merely guessing. If it actually IS bad bearings, they may go out the next time you start the motor, or, they may last another 50 years.... It's impossible to tell.
Old Apr 6, 2018 | 04:42 PM
Gharve88's Avatar
Gharve88
haha so basically just plan on getting a new motor and start fresh. At 171k miles not sure if its worth digging into it and tearing it apart.
either way I appreciate all the info and what u can tell me from what ive said. If i do a new motor i plan on doing a hughes cam and air gap intake
Old Apr 6, 2018 | 04:50 PM
Budget a custom tune in there as well then. And don't forget new heads. The stock fellers suck, and are prone to cracking.
Old Apr 6, 2018 | 04:53 PM
Gharve88's Avatar
Gharve88
oh wonderful.😐 any advice on the tune and heads? I know the stock cam sucks big time and i talked to hughes engines and they have theres which they said was amazing. Also a pretty penny🤑
Old Apr 6, 2018 | 05:48 PM
AtomicDog's Avatar
AtomicDog
All of this advise is dependent on your budget and time. If you have time and mechanical skills, you might consider what I did to get more life out of your truck and not bust your budget - my original 5.9 motor needed replacement due to major rust issues - I found a good used low mileage 5.9 motor off Craigslist that came out of a Dakota. I brought it home and put it on an engine stand to start doing a refurb job on it. I pulled all of the freeze plugs and cleaned out the cooling passages in the block and replaced the all of the freeze plugs with brass plugs. I pulled the oil pan and checked the bottom end. The bearings were just fine, so I put a new pan gasket on it, along with a high volume oil pump and screen and put that back together. I took my old kegger intake and swapped it onto the new motor. Also put in a new distributor, cap, rotor, plug wires and plugs. I also installed a new water pump, double roller timing chain/gear set, tensioner, belt and a set of shorty coated JBA headers (also found on Craigslist). I cleaned up the motor, painted it and installed it into the truck. It has run like a clock ever since.
Old Apr 6, 2018 | 06:30 PM
Gharve88's Avatar
Gharve88
thats very helpful I appreciate that. Well this isnt my only vehicle so realistically it doesnt need to be done tomorrow. Kinda giving her a face lift i guess. So i have time and id like to do things right
Old Apr 6, 2018 | 07:08 PM
Gharve88's Avatar
Gharve88
out of curiosity, if the cats were clogged wouldnt it throw a code?
