Knock on startup/5.9 magnum
Old Apr 6, 2018 | 07:29 PM
  #21
Originally Posted by Gharve88
out of curiosity, if the cats were clogged wouldnt it throw a code?
Not necessarily. The PCM only cares if the cat is working or not, and is pretty lackadaisical about what it considers 'working'....... It could be totally plugged up, and the PCM would still be perfectly happy with it.
Old Apr 6, 2018 | 07:33 PM
  #22
Gharve88's Avatar
Gharve88
hahah awesome. I live in a non smog valley and was wondering if i should run no cats or would this truck not like that?
Old Apr 6, 2018 | 07:34 PM
  #23
You could probably get away with it, and if your engine is in decent condition, it won't even be that much dirtier. (exhaust emissions-wise.)
Old Apr 6, 2018 | 07:36 PM
  #24
Gharve88's Avatar
Gharve88
alright cool I’ll probably do that. Im sure itll have a better flow anyways. I have a feeling my cat is clogged big time
Old Apr 7, 2018 | 07:09 AM
  #25
true blue's Avatar
true blue
In years past, bad lifters can also cause the "knocking" problem on start up. These are hydraulic lifters designed for maintenance free usage, but...they can and do fail. Also, are you using a good quality oil filter? Cheapo brand filters without check valves to trap oil in the filter for startup can let the oil drain from the filter causing a temporary reprime that'll cause something like this as well.
Old Apr 7, 2018 | 10:29 AM
  #26
Moparite's Avatar
Moparite
If your cat is clogged it won't rev up past a certain rpm. Did you do what i suggested in my last post? This will confirm if it's an oil pressure issue on start up or possibly worn bearings.
Old May 24, 2018 | 05:01 PM
  #27
Gharve88's Avatar
Gharve88
Default 5.9 knock on startup
So this is the knock i hear when i start it up after its been sitting for a couple hours. Hope the video came out
Old May 25, 2018 | 08:02 AM
  #28
Nope. Didn't post.
Old May 25, 2018 | 08:24 AM
  #29
Gharve88's Avatar
Gharve88
Nope. Didn't post.
sorry its not letting me post the video. Ill try again abit later
just at a point of narrowing this issue down so i have an idea. Mostly hearing people say its a rod bearing. The startup is pretty loud then goes away but can hear it alittle bit around 3 grand
Old May 25, 2018 | 10:57 AM
  #30
Ramman18's Avatar
Ramman18
When I had a noisy lifter, it was more of a pfft pfft pfft right at the initial rev following ignition. A "knock" should be more metallic sounding and deeper.
Valvoline maxlife cured my lifter noise over 100k ago.
