what is teh cause coil driver
Old Apr 12, 2018 | 12:58 PM
byteme's Avatar
byteme
Default what is teh cause coil driver
so second time in 4 years ive had this truck break down from coil driver failure Ive changed the coil two years ago .Im not sure how old the wires are but replace the cap and rotor ,rotor was burnt and arced found a huge crack running down on the outside I was told be the shop I had replace the coil driver said the coil causes the failure ??? Think ill replace the ignition wires just so i know
Old Apr 12, 2018 | 12:59 PM
byteme's Avatar
byteme
Default what is the cause coil driver failure p0315
Old Apr 12, 2018 | 02:42 PM
Coil driver is part of the PCM. if you keep going thru coils, I would consider a different brand part.
Old Apr 12, 2018 | 04:23 PM
byteme's Avatar
byteme
Default it gg
Originally had oem in it for a coil when the first one popped then put in a standard ( blue streak) hard to believe its just the coil. Im not sure im going thru coils but have popped the coil driver twice
thanks
Old Apr 12, 2018 | 04:47 PM
racefan41's Avatar
racefan41
worn/bad plugs and wires are hard on a coil.
Old Apr 12, 2018 | 06:02 PM
Moparite's Avatar
Moparite
P0315 No Crank Sensor Learned ???
Old Apr 13, 2018 | 02:14 PM
byteme's Avatar
byteme
sorry 0351 dyslexic
To clarify its up and running just curios of what kills the coil driver sealed inside the PCM .............
Old Apr 13, 2018 | 06:51 PM
Moparite's Avatar
Moparite
P0351 Ignition Coil # 1 Primary Circuit
What is the vehicle info and how did you get the code #?
