Will a 98 tranny from a 5.9 bolt up on my 2000 5.2
Will the transmission from this 1998 5.9 bolt up on my 2000 5.2 I'm hearing something about a flexplate and torque converter do I need to take the torque converter and flexplate from my 5.2 and put it on the 5.9 transmission
Will the transmission from this 1998 5.9 bolt up on my 2000 5.2 I'm hearing something about a flexplate and torque converter do I need to take the torque converter and flexplate from my 5.2 and put it on the 5.9 transmission they're both 46re
Thanks . I've been trying to get my 5.2 back on the road since the trans shot on me. I lucked up and bought a 98 with a 5 9 for a parts truck for cheep . Do you know anything about pcm flashing ?
well I bought a galletto 1260 and it came with some software but the only Chrysler is not a Dodge Ram it's some like Intrepid or something
I know I need a j2534 or a j2534 pass through and a subscription to the Mopar website but I would like to learn how to flash PCM and want to know if this thing I bought galletto 1260 is sufficient enough because I bought a 2001 Ram with a 5.9 is four-wheel drive none of the gauges or anything work so I put a different computer on it because the guy said the one on it needed to be flashed and all the gauges work I took the one off the parts truck and put on there and it worked until it got stuck in tow mode so I put the one for my 5.2 on there and it runs fine and all my gauges work but I'm going to need to put it back on it when I get the transmission back in it so any help you could give me would be awesome
Trending Topics
The info I can find on the galletto feller is kinda contradictory. It says it can read/write to the pcm, but, can you edit what you get? Doesn't mention that, so, I suspect it does not....
