Did I mess up my cruise control?
Old Apr 13, 2018 | 04:57 PM
Andrewgill210's Avatar
Andrewgill210
Default Did I mess up my cruise control?
I know there's been quite a few post on cruise control, but I can't find the problem. It worked fine when I bought the truck. I took the throttle body off for cleaning and when I put it all back together cruise didn't work. I don't think I broke anything and I can't find anything that looks wrong.
did I forget something? What am I missing?
any and all help is appreciated! Thanks!
Old Apr 13, 2018 | 05:39 PM
Ramman18's Avatar
Ramman18
Probably just bumped the vacuum line that goes right in front of the TB. It crosses from the check valves on the passenger side and ends up by the battery. The vac lines are very small (thin) and kinda hard like plastic so they can be brittle.
Look for the T at the passenger valve cover and check all the connections at the check valves into the manifold.
Old Apr 13, 2018 | 09:46 PM
Michael92's Avatar
Michael92
I would go and replace as much of your vacuum line running to your overdrive control. under the battery. I'd just snip a couple inches off the line coming off the port off the passenger side manifold and running it through the weird tube loom/mesh looking stuff that also has the cable, down to about a foot or so off that end cause it's kinda tight unless you take out the battery and tray.
Old Apr 15, 2018 | 02:37 PM
Andrewgill210
Thanks guy! As soon as it stops snowing I'll go through all the lines again.
